Kelsey, I'm very interested in your kit but I've got a few questions...
I've got a 163 XM estart, carbon can, C3 belt drive (25T, 63B), stock clutching
Riding generally 6-8000 ft, but sometimes 2-3000 ft
I do have an rk tek dealer (Specialty Sled) nearby. I live in Edmonton, AB. I plan on doing something in the off season when I know I've got something reliable to work with.
I don't know a whole lot about BB's, fuel controllers, and fine tuning clutches but I'm fully capable and I want to learn.
I don't necessarily need to ride around home and I do plan on buying another sled in the next couple years. I'm not sure if a fuel controller is absolutely necessary... However, a lot of the trail rides into where we ride are 3-4000 ft and go up to 6-8000 ft. Does this require a fuel controller (again I don't know much about them?)
What are your recommendations? (As far as:
-clutching
-cooling- Terra Alps racing offers a lower temp/higher flow thermostat and housing (opens @ 90F and closes bypass @ 120F... is it necessarily a good thing?
-venting- keep the CVT cooling shroud? panel venting? "Blow hole" hot air eliminator ok?
-fuel- VP C111 race fuel & 91 octane mixture ok?
-we still have 1/2 a barrel sitting in a dry cool dark place for a couple years now... is it ok?
-What fuel ratio?
-gearing- I want to keep the C3 belt drive... Should I be worried about gearing or field test first?
-carbon can... Do I need to run the suitcase? What about pipe and y pipe?
-Is this a job a competent HD tech can take on without really having to worry?... I rebuilt one top end, on my old rev, but the locator pin failed a few hundred km into its rebirth, took out the cylinder & kind of has me wondering if I made a simple mistake that cost me a lot or if it was just a fluke! I ended up putting in a short block.
I really want to do the work myself. Mostly to learn but also to save $...
