RK Tech Question
Vertical-Extreme
does anyone know if the RKtech drop in kit for the 3 series 800's will work with jaws twins, or do you have to run a single?
i beleive most all of his stuff is designed for stock pipes, all his bigbores he recomends stock singles, on the newer ones, i know his 734 in the old ones like twins, but who knows, give him a ring, kelsey is a wealth of knowledge
im just pre planning for next off season.....man i wish it would snow. But good to know I will give him a call when the time comes.
I dont know if I would say his stuff is "designed for stock pipes", rather he tests all kinds of pipes on his kits and usually finds nothing works better than the stock pipe. Call him and ask, I would bet there is very little, if anything, to be gained by using twins.
i think stock doo pipes have already proven themselves as some of the best stock pipe.
you get a really consistant sled, as the stock pipe are designed for consistancy.
if you have twins, give em a try, but i would NOT recomend buying a set just to run with his drop in kit, get the motor ported by him for less than the cost of a set of twins, and reap the low end grunt his porting has.
yea I have the twin jaws now, that is why I was wondering if they would work, I'm sure they would be pretty easy to get rid of, or trade if that is the route I went. but if they work then Im set. does the DPM still work with the drop in kit?
Why would you think it wouldn't?
