Revers Click/Grind?
From what angle are you able to look at the water pump without pulling alot off?? Just trying to inspect mine and i have no clue how you got a look at it or cleaned it off
I notice you have the fire and ice intake, that will probably have to come off. On mine I just pulled the belt gaurd, and if you shine a light at the right angle and look over the seconday you can see the top of it. Also used a dentist mirror thing (??)
Then just sprayed down the area with brake clean. Are you noticing coolant lose?
well i filled it up the other day...pretty sure i went to the fill line...but not positive..this is the problem. Went for a small ride. Checked it today about 5 days later...its below the line but i cant see any on the trailer bed or on the ground. Started a new post for this if you want to reply there so i dont fill this one on this coolant problem
