Can you replace the water pump shaft seal with the motor in the sled (06 M7)?
I just finished up a 700 rebuild.The problem is the pump shaft rust causing the seal to fail,then you need to split the case to replace shaft.You will also need the seal install tools.May just want to pull the engine yourself and take it to a cat dealer and have them replace the seals.You will have to take it out to do the job.Can you replace the water pump shaft seal with the motor in the sled (06 M7)?
There is a oil seal and a waterpump seal on that shaft it looks to me that the oil seal is leaking a bit. You can replace these without splitting the case, you must remove the oil pump and take the shaft out that side. Then you can access the waterpump seal and the oil seal. It will take some special tools and it can be done but unfortunately I believe the engine has to be removed for the job.
Hope this helps if there is anything else I can help you with let me know
Jeff
Gold CatMaster Mechanic
www.FunOutfitters.com
Free Technical Support Line: (866) 531-0123
If you look at part number 9 on this diagram it shows an oil seal right behind the water pump. This seal is to keep the gas/oil mixture from entering the waterpump area. If this seal starts to leak you will see oil leakage from that weep hole.
