Recall
J&L Snowhawk
Did everyone get the notice on the recall for the top gun 800s. 2007 only listed but our 08 has same problem. The coolant hose rubs on the voltage regulator and will leak in time. Just a heads up. should be easy fix.:p
The fix.
A hose clamp and some extra rubber like inner tube at the point of contact.
800HO's only, not a problem with others.
check all water cooled hawks
The recall only listed the 07 800 but I check my six and the same problem exists. the left hand cooler line rubs on the voltage regulator. The real fix is to remove the regulator and cut the first two fins back at an angle so the hose has more clearance. Puting more rubber over the hose is only a bandaid IMO
