Picture from above?View attachment 384084
This is what I’m using on my 165” Boost. I used the TKI Linq adapter plates and the skidoo fuel caddy. And then just moved the lock and ride bracket to the back.
Sent from my iPhone using Tapatalk Pro
Nice setup for gas. Is that the small bag?
Would you mind taking a tape measure and measuring the tunnel width at the outside edge of bumper bars at about where your fuel can is and at the back edge of where your bag is mounted?Mountain addiction 3.5gal / 13L can & small bag work well on the 165 tunnel. Just wish it held more fuel, I never seem to have enough fuel for this boost !
Cool thanks!@ fuel can = 17.5” wide including bumper bars
@ rear tunnel bag mount points = 16.5” including bumper bars
You need a stronger bumper…..Mountain addiction 3.5gal / 13L can & small bag work well on the 165 tunnel. Just wish it held more fuel, I never seem to have enough fuel for this boost !
What do you do when you want to stand on the rear of the running boards?View attachment 384091
The fuel can is 19” wide so it’s about 1.5” wider then the tunnel on each side.
Flipping through the owners manual for the 22 RMK Pro SLash Boost 165 I find this. GIven a gallon of gas is 6.3lbs, by the time you add weight for the can, mounts etc, you really cant put much if anything else on the tunnel. Wonder how much BMF Fabrications increases the weight capacity by.
I'm for sure getting a more stout bumper and reinforcement than what Polaris offers for options.With my backwoods bumper on my slash I can stand/ walk anywhere on the rear tunnel, and I'm 240lbs.
