I too, had the opportunity to make the sneak peak in Fargo the other day. I had the opportunity to speak with one of the Polaris engineers and the drive shaft issues came up.
I was told that the 13 drive shaft issues were vender related. Basically parts supplied by certain venders were produced with incorrect tolerances, causing the failure. They also claim that the new 14 could be run without the collar, without issue. The collars were placed on the 14 to ensure to their customers, there will be no issues, event though it's not needed.
We also had the chance to discuss the a-arm bonding issues. Polaris claims that the a-arm failures were directly related impacting some kind of object. They stated that several a-arm failure claims were examined and the ones they reviewed, they found evidence of hard impacts. Things like large gouges in the skis, bend a-arms and or other tweaked parts. They claimed, they could not come across one a-arm bonding incident that did not have some kind of hard impact.
They also discussed the testing process that EVERY a-arm goes through prior to assembly. They actually "pull test" every a-arm before they are sent to the assemble line. They also take samples of every run of structural adhesive, which is also subjected to tests and evaluation. If it fails, that run of parts is recalled prior to use.
Again, this is just what I was told, so take it for what it's worth.
The only other thing that I bring up or pose the question is reference the "collar fix" on the drive shafts.
Now let's just rewind or step back in time for a moment, and let's say Polaris placed the collar on all the 13's from the factory when they first released the sleds to dealers and customers. People take a look under their sled and find a new lighter weight drive shaft that appears to be beefed up. (what else can you say?) Cannot complain about, because you don't know anything about it yet. Now the season starts and NO failures are observed or reported. Now using this example, and comparing to what actually happened this last season, did Polaris "fix" the problem or simply put a "band-aid" on it?
Thoughts????????
