Your saying after the engine locked up, Dad fixed it. Correct
His dad did not fix it, dan did. Just having some fun with ya.
Nope. BROAD powerband at the top.
8000-8500 is the target.
That is likely due to the over rich map. If you have non ethanol fuel, make sure to take it out of ethanol fuel modeSorry I did not read any of the other post if this was discussed all ready. I rode my friends last week in the snowies. I believe it was still in break in mode. It had a hesitation when you grabbed the throttle. I adjusted the secondary as belt was a tad low but still had hesitation. Maybe something with the pig rich breakin mode? Did not feel that much stronger then 800 but again break in mode. It definitely has some snort to pull 66 gram weights at 10000 ft. I thought i saw 7900 on tach and i know my 800 wont spin 66 even close to 7900 @ 10000 ft. Thats all i know!
I've had two rides so far, 3.4 Hrs on my SKS 850 155". As others have said, I wasn't impressed with the engine at first, I love the suspension, it's like night and day compared to my 2014 Pro.
My engine has been bogging down quit a bit, hopefully this is just a break in thing. I didn't put oil in my first tank of fuel as others have said, hopefully this doesn't affect anything. Sled is still completely stock and I'm still running in the ETH setting.
Yea I probably should not even of posted that as my friend was stuck again (he sucks)!! I pulled up and he was wedged in some trees so i helped move the sled around and he asked me to drive it out. I did not give it back to him for 45 minutes and left him my axys. lol I only looked at the tach a couple times in 45 minutes and did not notice how many hours or if it was in ETH mode. I really cant figure out all these guys that are tree riding and looking at the tach for rpm? I have no time for that, too busy dodging stuff.That is likely due to the over rich map. If you have non ethanol fuel, make sure to take it out of ethanol fuel mode
I saw peak hp after break in was 8150 and tq was 8000 with hot pipe and warm motor. I would shoot for that 8100. 8500 she is falling off to much and getting to far away from tq. Just my 02. Plus i guess im an old school clutch guy and like to lug the motor a bit.
420 miles on 850 Pro 155 17 hrs, oil in every tank so far no fowled plugs, Thunder Products Clutching turning 8200 rpm this thing Rips with this New Clutch Kit thanks Tim H. of Thunder Products.
155 miles, 15.5 hours. Stock 163 2.6 track. Really woke up after ~12 hours. Before that thought it was more nimble than my 2014 pro 163 with stage 3 kit and 3" with avid drivers. But about the same power/Tq.
The last ride it was amazing! Track works well, probably as good or better than the extreme 3". Engine pulled very hard... been breaking single track trail in powder and boondocking meadows. Not many times I have enough room for full throttle, 3/4 torque is awesome for tight adventuring where it will get you out of trouble without a full throttle out of control manuver. On a tight little climb, I do every couple rides, with a series of steep treewell turnouts, it got me into the technical stuff so quick and smoothly... I had to purposly stick it as I am out of vertical treewell turnout practice so soon in the season. You know the ones your buddies can't come to help if they wanted to... but an easy roll from near vertical to get out.
Only complaint is it gets a lot of powder in the engine compartment that melts into a lake under the clutches. While sharp turn boondocking, i would get the "wounded seal" noise from a slipping belt. I tightened the deflection to lower the belt slip to the point of squeeling, without the self-drive at idle. Have to watch out if I put a new belt on in the field.
I'm a bigger guy so I will add a turn to the rear track shock now that the trail woops are forming and to ballance the ski pressure.
Sorry no rpm monitoring... when we get better snow coverage I will be able to properly check that.
Looks to be a great sled... it has to be because a tow out would be very difficult and we have a huge cougar protecting our trail head, so camping out might be risky![]()
