scooped some pulleys off ebay gonna try it out
love them tree's
thanks tb
Got them installed, so far really like the better low end grunt, they went right on with the belt/ziptie trick, ezpz for 100.00 on ebay its pretty much a no brainer if you want to gear down a bit for boondocking![]()
so if I leave stock axys top gear and put on Pro lower (44), will I still use the stock axys belt?
If i install the pro gearing, will my speedo still read correctly?
Kewl, did u gain any trax speed? Was clutching and rpms improved, pls share your technical observations.
My buddy is trying the pro gears on his axys today at lower elevation 2000-5000' , going to leave the stock helix, springs and the 10-70 weights in it for a far comparison.
Thinking about doing this eventually to my sled. I got Electric start. is it possible to do the swap without pulling the battery out? Haven't really messed around in that area much but it does look a bit tight.
