I am running 7T 3" pitch avids....
my secondary was pretty warm when i checked it... and i had it on the 60 setting of the helix
Rons weights did help out quite a bit, i was able to hold better rpms with the 1g heavier custom weight over a 10-58.
i kind of wanted to be able to run heavier weights to try to help my shift out as i am still almost an inch away from full shiftout.
When my sled was new Indy Dan balanced and worked over my primary.
How much bigger of a bottom gear can i squeeze in there with my stock chain?
honestly dont know how big a gear will fit..guys last season were running as big as 19/46 so that will fit....with out full shift out ..yea I would gear down..that will bring up the rpm..might also add a couple delrins to the secondary and a fresh spring if it has much time on it(delrins will smooth the shift and fresh springs do make a difference......if you could go up 20 pds on sec spring that would help also.(especially with a hot clutch...)
