Pure Logic Controler
When I start my sled I do not see the scrolling green lights like the instructions say it should do but instead it goes to a flashing green and red right on start up.
If I rev it just a little it will go to a solid green then I can set my modes but if I let off and the sled goes back to idle it returns to the flashing green and red.
Is it working properly and if so does that mean I always have to rev it a little to set my modes.
Im a turbo newbie here and any help is appreciated.
Thanks
that means no input signal. it is below the defined lower limits defined in the code for the engine to be running.
if you have to rev it slightly to get it to start scrolling and set your modes they should update the code so it works properly at idle.
What is defined lower limits.
Im getting mixed answers here. one says that it is fine and one that it needs updated.
When its idling the #1 green and the #8 red are flashing back and forth. If i hit the mode button it just looks like clark griswalds christmas tree with different colors in the middle then back to green and red flashing.
Could it be to low of voltage?
It came off the same sled just a year newer so I assumed that the program in it would work just the same on my sled.
