continuing:
3.4 hours this sled is just outstanding...bone stock engine/clutch now 8300 rpm's all day long...no heat and no belt fade. I'm exhausted before the sled is!
Next step I think clutching from Carl's. Was going to wait til turbo time but I want to know how much better this one gets stock. 8300 at 7000ft 38* heavy snow is leaving performance on the table. That said it flat out rips..can I really get from point a to point b faster with a Carl's clutch kit? IS there some more pull on the mid to top since it's spinning out too much? More helix first..then another gram or MAYBE EVEN TWO? What happens when we get into the less heavy types of snow? Man I hope so and it will just increase the wow factor!
SHOX? Well I'm really liking these FOX shocks and it's for the little things. Example: There was a fallen tree across the trail that we jumped over on the way in and it was fun...smooth...effortless. On the way out I was hauling the mail way too fast down the trail and here it was from the other way. Not where or how I remembered it (trail is 18 miles long) and it was dusk with freezing fog on the goggles. Came around the bend and there it was! Panic skid/slide...brain says hit it! So setup..compress the suspension....prepare to fly. (we talked about hitting this thing to test these shocks way up the trail and another guy wanted to do it..I didn't want to ride his sled all that way 2010 HCR stocker so I got this one back prior..kind of amped up to try it) Unfortunately the take off from this side is cambered badly towards off the trail into a creek. All things added up to a horrible jump and could have been very very ugly. Pretty good distance and air but I was all leaned over to the side and heading off into the creek side of the trail. Tail hit just before the left front shock and I was really ready for a painful mess (the kind where you grit your teeth and to quote Ricky Bobby "I'm flying through the air and this is not good". Sled flat gobbled it up with no jolting horrible wrist wrenching impact like when you case your front shocks let alone ONE SHOCK. Back didn't hop even though I landed tail first and was off of the throttle bringing everything forward. In my mind I just thought..WOW that was impressive and I'm very lucky. This was a bad landing that can sometimes bend the suspension rails and tweak a tunnel. Sled still looks good.
I also got to ride a PRO without Better Boards heads up in the same stuff with this sled. The stock boarded PRO while it isn't anywhere near as horrible for build up as the IQ RAW still builds up badly and requires attention. The Better Boards just flat out work way way better even on this sled. THIS IS AN UNARGUABLE FACT! Another situation that I noticed was that the stock sled had a more significant build up right in the footwell by the clutches. The Better Boards have a much larger evacuation opening right there so the snow has somewhere to go when you work your feet around. On the stocker it gets pushed up into the clutch compartment and reports say lead to problems. I don't have a block off installed yet but didn't get any slippage. Snow was heavy and was laying the sleds over in a couple feet of fresh to give it lots of opportunity to build up on the boards. Interesting!
clank.
When people ride these sleds in the hills I'm wondering how cat, doo, and yamaha can sell any sleds!
