The supercharger kits for the Pro 800 come with larger injectors and make 8 lbs of boost. This is the kit sold by Carls.
The delusion is strong in this one!Your delusion seems harmless, so I encourage you to maintain it.
If you knew who this is you would feel really stupid. He talked to Jack and we are both right in a way. Done with this.
The kit makes 7lbs at Brundage Reservoir. I spoke to Jack yesterday and told him about this post just to clear things up. At Wongs Bowl it is making 6.4lbs. It will obviously change with elevation. Without sounding cocky, this is the TRUE answer. He said expect 6.5lbs at elevation of around 8000ft.
You nancy's can't tell the difference between 6.5lbs or 8lbs anyway![]()
I rode the prototype unit last June at Snowbank. It has nice throttle response. It is not as strong as my old 09 Dragon Turbo but I didn't expect it to be. The only thing that I didn't like was it sounded like I was inside an old washing machine. Lots of mechanical noise which is to be expected. Maybe the honed in production version has less mechanical noise emanating from it. I guess that I will find out some time this season when I am out with the guys from Carl's. It is a very sanitary setup as one expects from Jack. I can't afford/don't need a turbo or a supercharger. I will be satisfied with a 16 with the H.O. motor and another reduction in weight. I hope that will happen.
It spools up instantly and has every bit as much throttle response as a 900, but with more bottom end and mid range power.
