Update;
1. Set the TPS.
ECU 4.996V
Before:
Base 0.714
IDLE 0.947
WOT 4.43
IDLE RPM 1750-1800
After:
BASE 0.700
IDLE 0.940
WOT 4.310
IDLE RPM 1850-1900
2. Sealed the whole exhaust system with black silicone.
3. Changed the clutch completely with new helix, weights, primary- and secondary spring.
Still only pulling 8200 consistantly, saw 8300 twice...
Been riding for 100km today.
Keep in mind the max. torque rpm is lower than the max hp rpm. If you load your motor for 8300rpm it will likely drop rpm but if you run at the max torque curve, you can hold rpm and possibly even have more track speed. These motors like a load so if you only look at trying to hold 8300, you likely will over-rev on the flats and might go slower on the climbs. Also I had a 2015 and a 2016 out last season and from one day to the next they both lost 200 rpm when the weather changed. Hard to clutch for that.
