Issues
I have 10 hours on my pro ride and the bog came at about 7 hours at 6500+ RPM it would slow then pick back up. As mentioned on another post on here check the plug wires and caps as well make sure you here the pop/click when the plug cap goes on. That was my biggest issue is the mag side was not all the way on and would bog all the time above 6500 RPM. This fixed it mostly. Now I think my throttle safety switch is no good it will run fine most of the time but when I'm on/off the trhrottle sometimes i will get a slight bog. The tss test does not shut my sled down when I test it i hold the pin back and tap the throttle and it should stop the motor but it does not. ????
