Final weld is monday,everything is tacked together. Next project will be an aluminum airbox that will pull air from behind the steering post.
I have received quite a few questions regarding this build and I will list some of the parts you will need to make it happen:
Power addiction motor plate
2- 70 liter fuel pumps
650 RXL water pump and Power addiction racing mag housing this is the only way it will fit in chassis without grinding the bulkhead
Power addiction racing flywheel hub---or machine your own flywheel with lathe
Jaws Pipes -They built the cones,chambers and head pipes for my engine and we fitted the pipes-roughly 30 hours
Flat slide triple carbs,rounds will be to bulky to fit
Tig weld a cover over jackshaft-used a piece of aluminum pipe and cut it in half
extra cooler under tunnel for cooling capacity
The Mag cylinder is perfectly centered on the center of the bulkhead, the Pto cylinder is inline with the steering shaft which has to be moved over roughly 2 inches.
Need an extra Torque arm on Carb side just like the stock RMK
and the 2 things I have used the most in this project are My Tig and Mig welders along with the lathe, there is no way you could accomplish this project without all three of those tools unless someone else machines for you.
Im leaving out some stuff on here Im sure but this is a list of the expensive parts.Any questions feel free to ask.
