Trying to replace antenna mast on 2001 Toyota Sequoia. The plastic drive strip broke. I removed the broken remnant from the motor housing too, and checked the drive gears to make sure they were not stripped. The new plastic and the old plastic measure the same length so I know I got all the old out.
When I turn the radio on/off, the motor will not run more than a second or two. Not enough to pull the new plastic strip in. In testing the motor with no strip, about 10% of the time the motor will run longer than a few seconds when turned off.
Also, I measured the length needed to insert plastic strip to where it engages the teeth, and I have the teeth facing the correct direction to engage the gear (toward the motor).
One time I was able to get the strip pulled in about 6"(after numerous on/off cycles), but then it wouldn't go any further.
Is there a trick to get the motor to run longer or do I have a bad motor?
