poo primary on a doo?????
ragincajun
hey guys and gals,
my doo primary is toast and it is gunna cost big $$ to fix. doo qouted me $1300 for MOST of the parts i need to rebuild it. anyways who has put a poo pirmary on a doo? i like the low cost factor and the simplicity of the poo clutch....but i also like the clickers on the doo primary. i know the taper has to be machined to fit my pto end. who out there has this set up and how do you like it? if you have any info please pm me or just reply to this!
thanks in advance!
If your gonna put the P-85 on there (highly reccomend it) , be sure to have whoever cuts the new taper to also balance it , might save you some pto bearings down the road...
Very easy to tune , parts are cheap , and yes you can use your doo belt ( I wanna say its the (127) if its in an S-chassis.)
....Don't throw your Tra clutch away if you do decide to go with the P-85 tho... When flipped upsidedown you won't find a nicer ashtray, and the ramps with a little grinding can be made into some handy bottle openers.
