E
Never seen that... but if theres no other damage and its on the seam I would try to get it warrantied, looks like something you will probably want to replace regardless.It’s possible I guess. I feel like if I hit something hard enough to tear it like that that it would have torn a lug or frayed the edge of the track or something? Weird rip on it. It actually looks like it is coming apart right on a seam where the track was bonded together?
Poo’s mountain tracks certainly aren’t known for their durability... its no secret, but I’ve never seen one tore like that. Typically people just have issues with lug tears and such, not the actual belt itself.The rest of the track looks mint. I’ve got it in the dealer now and they are working on getting another track here to replace this one. Hopefully Polaris will warranty it. I’ve got to question the durability with only having 75 miles on it and then this. I rode my doo 850 for 800 miles last year in some very questionable snow and never an issue
I had a buddy who had an Axys 800 and his track flat out ripped in half and came shooting all the way out from the sled off the drivers when he was pulling a hill last year. I’m glad I found it when I did and didn’t have to deal with it on the mountain. If it doesn’t warranty is it possible to change the drivers to 3” pitch and put a 280 on it with the stock belt drive? Or does the stock belt drive limit me from making that change?Poo’s mountain tracks certainly aren’t known for their durability... its no secret, but I’ve never seen one tore like that. Typically people just have issues with lug tears and such, not the actual belt itself.
Going to 3” pitch gearing lowers the gearing, not higher. 3” are smaller in diameter drivers than the stock 2.86 drivers.
7x3=21” circumference
7x2.86=20.02” circumference.
Might wanna run the math again......
So theoretically a guy could leave the stock belt drive and put 3" drivers on to run a Camso 280 (or any other track with 3" pitch) and replace the stock track out without changing the gearing?This is not always the case, if going from stock Poo drivers to Avid extroverts the Avid 3’’ pitch drivers are more or less the exact same circumference, Poo 2,86’’=Avid 3’’, hence gearing is not altered.
Measured this while changing my track last winter.
I haven’t ever measured avid vs polaris drivers. But the answer is no matter what you do you don’t HAVE to change the gearing. All comes down to preference.So theoretically a guy could leave the stock belt drive and put 3" drivers on to run a Camso 280 (or any other track with 3" pitch) and replace the stock track out without changing the gearing?
I don't personally know enough about the driver specs and gearing ratios on track swaps so all this input is greatly appreciated. I am certainly not settled on the 280 and honestly I kind of the like that Camso has a 2.7" lug profile track. I thought it was either a 2.5" or 3". This whole conversation started with the durability of the stock Poo 2.6. I didn't mind the performance of that stock track, but also want something that will stay together. As I've said earlier I put 800 miles on some questionable snow on my Ski-Doo 850 with the X3 track and no issues at all with durability. Still waiting to hear back from Polaris on a warranty on this track and if they do I'll obviously keep everything stock but if they don't, I know I could do a track swap to a Camso along with a driver change for less money than what Polaris charges for there 2.6.I haven’t ever measured avid vs polaris drivers. But the answer is no matter what you do you don’t HAVE to change the gearing. All comes down to preference.
In theory(if true to size) a 3” pitch driver will raise you from a 2.22:1 final drive ratio to a 2.12:1. IF you want to get back closer to stock gearing the easiest method would be to put Pro RMK sprockets on, it would bring your gearing slightly lower than stock to 2.27:1. I PERSONALLY would want the 2.27 ratio if I went to 7 tooth 3” pitch driver.
If any of my numbers are wrong feel free to correct me. Like I say I don’t know how avids compare to polaris drivers, but the above numbers represent drivers that actually measure 2.86” and 3” pitches.
I see you’ve mentioned the 280 a couple times... I’d do some research on that track before pulling the trigger on one. It may work for you and your snow, but most dislike the performance and durability.
