Polaris 2025 improvements.
No more TSS!!! Throttle cable is coated now instead of bare steel cable. Brake software has also been updated if you watch Turcottes release video. They say after 3 seconds of both brake and throttle application a light comes on the dash, after 5 seconds engine goes into valve down to reduce power. If you fully release the brake or throttle everything resets and you are good to go. No more restarting the sled to get out of limp mode. All the changes sound solid to me. Only worry I have is the new drive shaft. Polaris doesn't have the best history with new drive shaft designs. Do all models get the new drivers or just the 9R and Boost?
I wonder if that brake software update will apply to the '22's? Going into limp mode at the bottom of a steep dive and turn really sucks!
It's forged now, which should theoretically start to bend or deform before just shattering apart
Its not the spider its the bolt carrying the whole load the spider should be carrying . Poo knows what it is but knows it means a complete redesign and replacement . They should just send everyone a p85 as this new clutch is still gonna launch to space
Watch Turcottes YouTube video on the 2025 launch. The abuse those guys put on the sleds if the brackets didn’t bend or break then they won’t.
I am seeing some 2023 Boosts out there for ~3k off. Makes me wonder if it's worth rolling the reliability dice and going with a Carl's 9 boost
24 boosts should be coming in around 2-3k off, 23 boots 5-6k off MSRP.
Heck yah you should mod one out with the 900!
Polaris durability testing is sub par. I wouldn’t trust anything new and improved from them.
2.75 track still trying to run center driver first year. P-22 clutch. No need for rail caps. I’m sure there’s more
Whow!! kudos to Polaris.......sounds like a complete and total redesign. Big changes for sure. The '25 machine will be totally different and much improved.
My recommendation would be to build some basic weight transfer into the Khaos. How about if we start with that. I mean wasnt that the whole idea?
Does the 2025 cabe work in the 2023 throttle body I am wanting to switch over everything including to the new set up
We put a 2025 cable on my buddies 2022 boost, no problems. Well, not fitment problems.. The issue currently is getting your hands on one. Backordered for a long while.
I got to hand it to Polaris they are getting the sleds pretty dialed they’re not perfect but reliability is definitely better and they keep trying to fix the P-22. I installed the 25 tune in my boost and it was a big improvement. I have a lot of the TRS goodies on my sled which helps a lot too.
Can you describe the runability changes with the tune?
