Having some issues. My High flow intank pump went out. Then I put a brand new Walbro 195 intank pump in it. Still wouldn't run right and build fuel pressure. I changed out the regulator and installed a Turbo Smart FPR. That thing ended up in the garbage. Put a Bosch on it and now it seems to build good static fuel pressure.
Now that I have the fueling system working, I can't get the POS to pull above 4600 RPM. Acts like the ECU is sending a Code, but no codes are flashing. Kinda acts like when it is low on Antifreeze. Antifreeze is full. Just acts like the engine timing is retarding for some reason. I can't put a finger on it.
Anyone have any idea's?
Thanks in advance!!!
One thought: Have you pull the leads off of a sensor to see if you do get a code. Maybe you have codes, but no display?
