It almost sounds like the throttle safety switch in the the throttle block, I would try and unplug everything going to the handle bars and run it.
Other possibles but not likely as the way you discribed but, have you checked to see if the power valve servo motor is working, take the cover off and watch for it to move, you may want to pull the PV and disconnect the cables fro the servo, then pull on them and make sure they arent binding.
I also heard once of a guy that had problems because of the brake light wiring, the system needs the brake light working and nothing shorting or drawing power from it or it will rob power from the servo motor and make it run like dog chit.
There is a main ground on the mag side of the motor. Where the steering loop bolts to the bulk head. it is on the inside of the bulk head attached to one of the bolts on the steering loop with a nut on the back of the bolt. Many guys that don't know about this screw it up (twist it off) trying to replace the steering post because you have to take off the nut first to get the bolt out of the loop. It is hard to see.
Is fuel pressure staying where it needs to be. Heard of this a few times, the smart valves in the tank will not allow anything but gas through them, so if there is water in the tank it just wont suck. Just for what ever reason I would drain it completely and put new fuel in.
Or your fuel controller took a chit.
