T
theshadowrider
After reading numerous threads my theory is that two many reasons the dragon motors are going down is lean midrange, I have a fuel controller and egts now, and pistons slap causing piston scuff/failure. I want to put a new topend this summer as preventive maintenance, but want to make sure things are up to spec. My understanding is that some oem pistons are out of spec causing slap and either scuffing them or breaking off piston/cylinder skirts. Also wondering if maybe the cylinders are out of spec also.
Wondering what the piston to cylinder clearance should be on a 2008 dragon 800, and more importantly how to check it? Some have told me to use a feeler gauge but that seems not that accurate. I am thinking of using a micrometer to measure the pistons and then this dial bore gauge http://www.eastwood.com/dial-type-cylinder-bore-gauge-kit-2-6in-range.html?srccode=ga150120
to measure the cylinder. I am putting a new topend and I am going to put the wiescos in it. On the pistons they say to run the clearance to oem specs. The manual that I have says .0037" to .0053". Any tips, or is this correct? Thanks
