Or new sled... toying with the idea of a leftover 2015 but RMS is out of the RMK 155 without electric start (8390 for the non-ES version)...next step is "new " stator!![]()
I bought a replacement stator off of ebay from a parts place in eastern WA. No change in no-start condition, and both stators ohm'd out as ok (no guarantee I know it could be bad too).It sounds like you have 2 problems:
1) Stator is bad.
2) Possible wiring/connection issue causing the 7 injector blink code.
SledGuy brought up an important possibility. Could you have spliced the injector wiring incorrect? That would allow the ECU to energize the incorrect injectors which 'could' contribute to a no start. This shouldn't cause the 7 blink code you are having though since the resistance between the injectors is the same. It sounds like there is an intergrity issue in the wiring or possibly an open injector. However, it sounded like you had stated that you had backprobed the 4 injector circuits.
I have a stator from a 2010 Dragon that I parted out that only has 322 miles on it. If you're interested.
I think you have a bad stator. I have seen 1 Dragon that had a 7 blink injector code that ultimately required a stator to fix.
The relay's will not cause a no start.
I played with those 860's back in 08-09. learned quite a bit.
I put my ECU into a running dragon and it ran fine. Plugged his spare VR into his sled and started it up and all systems on his sled still normal. Put that VR and my ECU into my sled, still no start. No power commander since it is a carls 860 reflash.If you have another Dragon close by, regardless of year 2007-2010, try swapping the ECU and Voltage Regulator before doing anything else and report back.
We are just trying to start the engine. Don't worry about the mapping in the borrowed ECU.
Also, can't remember if you have a Power Commander or any other brand of fuel controller. If so, remove that also for testing/diag.
When I rewired the upper injector (1 injector wire was intermittent and it was pto upper cylinder, according to digital wrench at the time) I only rewired the 1. I checked the others with ohmmeter and they checked out fine. I wrote down the wire colors before splicing that injector wiring so I am 99% sure I got it right.
Remember that just by ohm checking your stator(s) doesn't always tell the whole story. There are 2 engine speed sensors on those assemblies that can malfunction as well.
I would still replace the stator, check the flywheel closely.
I know what you are getting at and in part I agree, but the crank position sensors help the ECU decide when to squirt fuel and also there are separate coils in the stator for generating electricity to fire the injectors (as I read the stator wiring diagram in the service manual), so if either one of those fails... no fuel. The 2 crank position sensors read a different pulse "ring" if you will since they are offset from each other (one is closer to the PTO side of hte motor than the other), one is a 5-pulse, the other a 2-pulse if I recall correctly. However I do not know if the 2 crank position sensors both, or which one, tells the ECU when to fire injectors and which or both tell the ignition coils to fire. The ignition coils are firing (after all my switching around I am going to check that again tonight with fuel in the spark plug holes). So it could possibly still be the stator.How could it be the stator when it runs when you dump fuel in the cylinders. I would be looking at the fuel system and electrical associated. If you have good fuel pressure then it is injectors, injector wiring or Ecu.
sled_guy, that is great to know, going to borrow one of these from a Dragon riding friend also to make sure it cures it (and not a wiring problem), the buy a new one if it does...Yay!!!!
I just had the 2 blink on the 860 I am working on. The temp sensor appeared fine, but no temp reading on the dash. And at time the thing could be a bugger to start. Put a new temp sensor in it, blinks went away, starts easy, temp reading on dash.
sled_guy
According to Babbits part online:Well at $165 it isn't exactly cheap, but I understand your thinking.
Just got through putting a new VR and computer on the 860 I have in the shop. It was the original VR, went bad, killed computer.
If you have one of the original VRs then I would HIGHLY recommend you replace it with the updated one... the updated ones have a protection circuit in them that keeps them from frying the computer.
sled_guy
4013587 - This is the latest one. Supposedly won't fail, but I've had one fail on a customer's sled, didn't kill the ECU.
4011731 - This is the original one. If you have this one, don't use it. When it fails it will kill the ECU.
4012930 - This is the 2nd version, I have had 3 of them fail on customers' sleds, none killing the ECU though.
sled_guy
