I ordered mine with out reverse so no broken bolt problems or shifting problems and I saved 9 lbs. and its for sale.
My push button reverse works flawlessly!
Maybe you yammy guys should ditch the antiquated levers and gears and move to a nice modern two-stroke!
what Joa said is totaly true. rock the sled back and grab the brake before you put in in reverse. works every time! im sure adjusting the linkange would help but ive never tried.
What a bunch of fricking cry babies. How about selling your Nytros and buying a 2-stroke? Then you can post how big of a POS the RER/PERC systems are when your engine dies in the middle of switching from forward to reverse.
It isn't THAT hard to shift the sled into reverse.
Oh, BTW, I didn't design the system or work for Yamaha. Maybe a little bit of patience would go a long way next time you're throwing a temper tantrum about reverse.
what is the deal? i tried shutting off motor, some times works. then move machine forward a bit and still a PIA! is there a fix?the chain is not over tight or loose. really stupid deal.
Your belt is most likely to tight. remove the shims from the three bolts on the back of the secondary. This will unload the drive train and make it much easier to shift.
They have internet at the farm ?? wow !![]()
agreed this has got to be the stupidest setup I have ever seen![]()
Are some of you guys retarded? No, honestly, are you retarded?
I am confident that is the issue...thanks for your genius intellect and your razor sharp skills at winning friends and influencing people...
go back to your cave troll!!!![]()
