I also had the clutch/engine balance done on my 09 Summit, checking that all internal parts were exactly matched and all bushings were good before sending in. After running it I can say that it is much smoother on the idle and smoother through the whole rpm range. Lined up an 07 800R, 08 800R, and my 09 and the difference was very evident. That was all at the shop, then we went for a ride. The sled ran very well prior but runs even better now. Had to wind out my Shockwave 2.5 degrees just to get it down to normal operating rpm on #1 for testing. Just added 2 grams in the pin, .9 in the middle hole, and 2.2 in the bottom to try and get it back down to a better angle on the helix and keep it from over rev. I'd say that it works, best money I've spent so far on the sled.
That's impressive. New buttons, o-rings & bushings will tighten up your clutch & require more weight. Could this be the case or do you credit all of this increase to Perks? Anything else changed? Pistons, head, pipe, different belt, snow conditions or elevation?
