Patriot Boost mufflers/cans ??
Anyone get a good look at the boondocker tunnel dump exhaust yet? Curious about the factory battery location
Ya they’re not that great. Hope the production ones are better.
On a side note, I see in the catalog they are $399 didn’t think that was too bad of price
I have always been an SLP fan, especially since they are right down the street, but I must admit the Silber looks much better at first glance.
I'm curious what the sound of each is.
(I won't even think about putting mine on for a month or so after I get the recalls done)
How far in did you cut into the heat shield from the side and top? Did you use steel strapping to attach or drill a hole in the muff pot mount and use the shield bolt to bolt it to the muffler?
5 3/4" down and 3 1/4" around from back. I actually cut off the top shield bolt bum off to allow the cooker to rest against the can. I used the hose clamp. The shield bums get in the way of mounting the cooker against the can. If they would of placed them in different location, you would not have to remove bum. I thought about putting an aluminum spacer between cooker and can to clear bum.
I used to just wad up a bunch of aluminum foil and put it between the can and the cooker to help with heat transfer.
Looking forward to 9R as well.
Have one of each on the way in identical trim.
Will see which is the better sled.
