Yes you can paint it. You have to sand it first to get the paint to adhere.
I have a limited edition white hood on mine... I am hoping that I can sand it down and touch it up with good results....the side panels are cast in white plastic..wish they had done that with the hood.
Actually, the painted hoods are made from a differnt material...
The red hood from the 2011 on the Std RMK and the Black hoods on all other models are made from High Density Polyethylene.
The painted hoods from those years (blue, white etc) are made from TPO (Thermo-Plastic Olefin).
Of the two .. The TPO paints easily... the Polyethylene, not so much.
See the posts above after I graft the threads together.
Please read from top to bottom... lots of good info here.
MH.
1) Do you know if the RED hood from the 2011 RMK (that you referenced above) is the BRIGHT RED that would match the red side panels on a 2013 PRO-R?
2) I'm in the process of a MINI-RZR 170 build for my daughter that has the 2010 PINK plastic body on it.
a) I need to do some "accent painting" on only small parts of that body & hood & rear fender area
b) Any idea of the type of material POLARIS used on the body?
Decent match, yes... but it is molded plastic and not paint like the side panels... not glossy, nor with slight metallic like the side panels.
I can't speak with 100% confidence on the 170... but Polaris seems to use either HDPE or TPO for most parts... HDPE has a texture... TPO is usually smooth.
Have you drilled or scratched it yet?... Do you know for sure it is "through and through"
