P-22 Boost Clutch Puller
R
Sep 30, 2021
18
Washington
I am having a hard time finding the correct clutch puller. Does anyone that has actually used it know the correct one to order. I bought an EPI one that said it worked for the Boost but it does not. the clutch is not threaded the same as the UTV that puller was designed for. I am finding the same one listed as the correct puller online and don't want to order the wrong item. I am not sure if the water trick would work on this clutch or not, I just want to put the new one on. Any help is appreciated.
  • 1 Star
Reactions: TRS
R
Dec 24, 2008
195
93
POLARIS CLUTCH PULLER XP PRO, RANGER 1000, 850 BOOST​
Model EP-PCP-24
Condition New
PCP-24 (PCP24) Fits:
Polaris - OE PU-52422
1000 Ranger 20-21
1000 Ranger Crew 20-21
1000 Ranger XP 2018-21
1000 Ranger XP Crew 19-21
RZR Pro XP 20-21
RZR Pro XP 4 20-21
RZR XP Turbo 2021
850 Boost Turbo Snowmobile with P22 clutch
  • Precise machining for accuracy
  • Manufactured from the highest quality steel
  • heat treated for superior strength
R
Sep 30, 2021
18
Washington
Model EP-PCP-24
Condition New
1000 Ranger 20-21
RZR Pro XP 20-21
RZR Pro XP 4 20-21
RZR XP Turbo 2021
You have personally used this product to remove a clutch from a Polaris Boost sled and it works?
R
Dec 24, 2008
195
93
i have not. had my boost since the 31st. i have this puller and have used it many time on the rangers. looks like the same clutch to me and just saw that it lists the boost as well.
R
Sep 30, 2021
18
Washington
I must have been sold the wrong one I wish I had taken note of the part number before returning it. I talked to someone else and they thought it seemed odd that it doesn't work too. Hopefully someone has some more information and can confirm the problem is the part or that I had the wrong item.
R
Sep 30, 2021
18
Washington
A quick update. I just ordered one from SLP and they have a different part number for the Boost listed than they do for the Polaris UTV's.
R
Sep 30, 2021
18
Washington
OK for anyone that is watching for answers or stumbles on this later I have an answer. I took it in to Kurt at Fastrax here locally and he showed me how to do it. The puller from EPI does work but does require some extra steps to pull the clutch. The clutch cover needs to be removed first and after removing the cover and spring there is black bushing that you can pull off and that allows the puller to go in further and thread. The bushing is about 1 1/2" and looks like an extension of the clutch but just pops off if you twist and pull.
  • Wow
Reactions: scc3
sledhed88
671
14
18
Is the dalton DCP-t the same design puller as the EPI PCP-24 ?
Do the clutch covers and sleeve need to be removed to use both or just the epi puller.
