J
Johnmaster
Propane has a lower BTU content and in NA 4 stroke applications that is the truth, you'll usually get about 80% of the power as gasoline burning the same volume of fuel in a healthy motor. I think in this case the fuel system is a big crutch that the fuel controllers try to work around, with propane having it's own fuel system specifically tailored to this application it helps it make more power more efficiently (or at least closer to the same). Propane also gives a much cooler charge.
In my mind it would be the equivalent of having a car with a carburetor with the wrong jets, squirters, cams and float level. It would be great if you could just fix all of those problems but if you can't then a more efficient fuel system will give it more power and better economy in spite of the slight difference in btu of the fuels. It's just a bonus that the fuel is a third the cost or better than equivalent octane.
This is my opinion, maybe Travis can confirm or deny some of my ramblings.
