Dyno is a tool.... not an absolute.... unless you are selling products or trying to win forum arguments.
OP... set your sled up to whatever rpm you are happy with 7500-8500... it is your sled.
You asked about 80gram weights and mention 4 grams heavier-- so you have a 23. 2023 runs a straight 46* helix. 23 fuel map pulls harder than a stock 22.
People responding had your best interest in mind when they suggested 8500 rpm is fine on a boosted motor. Polaris engineering sets up RMSHA sleds to pull 86-8700, RMSHA racing is not about longevity but power. I can assure you the sleds are faster at 86-8700 rpm. I have the on snow data logs (versus dyno charts) that show both track speed and GPS speed.
Performance wise, RPM does not equal RPM. Riders need to pay attention to track speed. Clutch settings, helix, mass distribution/ profile on weights affect this. 8600 rpm and 30mph track speed is not good. 8400 rpm and 50mph track speed (as close to similar conditions as possible) is better.
To the OP, if you add 4 grams of weight to your sled and change nothing else, you should feel lower engagement rpm (more mass overcoming spring 165lb starting rate), and a reduction of around 400 peak rpm. Will it make your motor last longer?..... unknown.
