Nytro Won't idle down normally
Brutis20
Not really bad, and will idle down eventually but when I let off the throttle it seems to take a bit longer than normal to idle down. Doesn't really effect riding but curious if anyone has had something like this. Its a 08 with MCX 240 kit.
check your throttle cable, may be to tight, do you ever see code 84 pop up? do you use an engine kill tether ?
Got it figured
After digging around I noticed that my intercooler support broke, must of been a while a go as the intercooler shifted down and the intake boots to the engine were all off, not completely but definately not on all the way. This is why when around 10+ psi of boost it would start acting up (this was a problem that came shortly after the idle) which makes sense. Anyway built a new bracket and tightened everything back up and she's pulling like a freight train again.
Thanks
