nytro with Timbersled questions.
gulfi
hey there, some of you should be running timbersled rear and frontend on your turbo nytros.
im riding a -10 mtx 162 wit McX 270 kit
and i bought barkbuster frontend, narrow one.
what angel should i aim for with the spindels?
and mtn-tamer rear and i´m thinking if i should use the suspension setup in the rear timbersled reccomend or if you have a better one?
for the rear do what they say on the shims and PSI, and the front shock in the skid i run a little more... about 70psi and let the limiter strap down 2 holes from recomended because i didnt like that much ski pressure. its all up to you once you ride it
okay, so then i will start there and then c what needs to be done :-)
i dont like to high ski-pressure ether, they just slow u down when they are inte the snow :-D
THX
/nisse
Angle of the front spindles should be as close to zero or vertical as possible with weight on it.
