--------------------------------Must go so make an offer---------------------------
--------------------------------Looking for nitrous kit-------------------------------
-------------------------Looking for 121" rails and rad shroud---------------------
-Boost it fuel system (knob style) used for 1hr till motor blew.
-Custom aluminum intake manifold
-Air to water intercooler w/rad
-16t mitsubishi turbo
-HD seat bracket/turbo mount
-Hot pipe from header into turbo exhaust housing
-msd fuel pump
-powderlites valve timing jig
-powderlites head shim
-digital air/fuel guage used for an hour before motor blew
-digital boost guage used for an hour before motor blew
-fuel pressure guage
-ulmer clutch kit (supertip weights, k helix, and primary spring) set up for 10lbs of boost
-Holley HD fuel pump (Used for return oil pump)
Motor parts (anything can be split up)
-damaged head w/cams and valves (one combustion chamber dinged up and the valves in that cylinder are bent or broken)
-Block with crank and two pistons and rods (one cylinder nicked up, needs to be re nickle plated)
-Throttle boddies w/injectors
-oil pan
-oil pump and chain
-side cover
-stator
-balancing shaft
-timing chain
-probably missed a whole bunch so just ask
---------------------------Must go so make an offer--------------------------------
---------------------------Looking for a nitrous kit----------------------------------
--------------------Looking for 121" rails and rad shroud--------------------------
-msd fuel pump
-oil pan
-oil pump and chain
-side cover
-stator
-balancing shaft
-timing chain
