snwman77
Banned
THIS THREAD IS OUT DATED!
Ok I just bought a 2008 M1000 with the Boondockers Race gas turbo on it.
I took it out for a very short ride at at rabbit ears this past weekend.
I would rate it 6.5 out of 10 as it is right now. It was set up to run on 110 race gas but it has LL100 in it. It runs bad on the bottem end, and a bad lean bog when you hamer the gas and it pulled like a pump gas M8 on the top end. (boost turned all the way down)
I will update this post once I ride it with all the BD updates that I plan to put on it. All updates should just over a $1000 with no oil tank or smaller inercooler updates.
Heres a list of updates I have planed for it.
High out put in tank fuel pump and take the stock and in line pumps off it, new updated pop off valve on inercooler, air temperature sensor update into the inercooler, wire harnes up date to air box injectors, Wastegate Controller, up date, Doondocker box reflash, fuel pressure regulator and fan for the inercooler. with just a wide band o2 sensor gage for engine monitoring.
I think this will bring the sled to a nice 9 out of 10.
