Did some math, I figured it would equal going to 19-45 with stock drivers...... thinking hard on this one!
So would you recommend putting a ce 2.5 track on a 7 tooth driver 2.86 Pitch on a Stock skid with the front cooler removed, would it have adequate clearance? Or, would you still recommend a drop and roll kit?
The 155 or 156 OR... 163 or 162??
Depends on if you want a ported track or not....one is a 2.86" pitch track the other a 3" pitch... the 55 & 56 fit on the 55 rail... the 62 & 63 same rail.
Larger driver with a D&R may be the way to go... We'll see when the reports come back..The only Pro Chassis sleds that I know of with a D&R, actually an extended chaincase (because the jackshaft cant be dropped any further) are highly modified machines with different suspensions and other goodies.
Best to compare apples to apples.
Until someone actually installs the 7 tooth drivers in an actual Pro chassis and checks for clearances installed (clearance to the roof of the tunnel, top of the front swing-arm etc)...
Whos First??
Whos First??
So...I need new drivers since my 900 ratchets like crazy as soon as the skis lift, will these drivers work with a Camoplast series IV? or should i buy the old kind?
You should run Proper tension IMO... It shouldn't ratchet that easily.
Set it to the factory specs.... 3/8-1/2" space between the rails with 12 lbs sitting inside the rails, on the track, with the rear suspended and the brake off.
The Avids are a great way to go to limit ratcheting..
You will still need to run proper tension, even with the Avid Combo drivers, if you want the TRACK to perform well.
MH
tried running it tensioned exactly like that and as soon as it got steep and deep(or just deep) it started ratcheting and i had to let off the throttle completely to get it to stop(= getting stuck). As it is now i have to have it like a violin string and i have to have the skid set up for as much ski-pressure thats possible and the limiter pulled as tight as it can be, and when the snow is heavy it still ratchets when the skis come off the snow![]()
If you are still ratcheting it is very likely that the rubber lugs on the track are torn. I had the same issue.
nope the track is brand new(and looks brand new, no torn lugs), i have put under 300 miles on it and it ratcheted ever since it was new.
its a switchback nine extended to 155" and running 18/42 gears
Did you change the drivers on the drive shaft?
Didn't the switchbacks come with 2.52 pitch drivers originaly? I know my 600 switch did.
Sorry,
I am talking 2008 dragon 800 155. Waiting to hear about someone running a ce 2.5 on avid 2.86 pitch 7 tooth without drop and roll and what kind of clearance they have?
This the question I have as well. I was set to go with the 7 tooth 2.86 with my CE 2.5 track but it sounds like I may end up with clearance issues somewhere else? Any confirmation on this yet? Sled is 09 D8 155. If there are other issues then it may be better to stay with 8 tooth driver and deal with tight tunnel clearance?
Let's hear it.
Still waiting to hear. I am now leaning on going with 8 tooth 2.86 pitch and doing the holz drop kit ...
