No... 7 tooth is only availble in the 3" pitch... the 2.86 and the 2.52" pitches would be too small in a 7 tooth
Hmm.. good news... I guess...
Robbie IS the man!!
It gives you about 1/2" more clearance than the stock... but you will have move the front torque arm bolt down a bit and suck up the limiter strap...so the top-inside of the track doesn't rub on the swing arm top tube. Changes the geometry a tad as well as well as decreasing the travel and affecting the ride... that much smaller driver brings the top-inside of the track down in contact with the swing arm front tube.
The stock 8 tooth 2.86" pitch is 7.25" dia..... 7 tooth 2.86" pitch is 6.37" dia
When we were working on these new ones he said he wouldn't make them as they were too small.... I wonder what changed his mind... Maybe Robbie will chime in here.
I have the 7 tooth 3" pitch Avid drivers that Robbie made for me in the pics above that started this "new driver thing" .... In my Dragon chassis... I have the Timbersled skid in my sled and it has a shorter wear bar than the stocker....I can barely stick my pinky finger between the two (just went to the barn and checked).
The skid is in the factory holes
My track is factory Polaris tight.
The 2.86" pitch 7 tooth drivers are even smaller than mine.
The Assault front torque arm mounting hole in the tunnel is lower than the RMK's/Dragons from what I've been able to see.... I think that would account for the difference between our two sleds in this dimension.
MH,
I have the 3" Avid 8tooth drivers & Timbersled skid. Have been considering going to a 7 tooth 3 pitch Avid driver so I could gain more clearance and avoid going with a D&R. The 8tooth worked OK but there was more clearance to be gained in the tunnel IMO.
Do you consider this worth the time & effort?
Thanks in advance,
akrevrider
here is the link to the NEW style drivers...they are listed under the Power Claw, but will work on all tracks in that pitch style..
https://www.avid-products.com/store/ProdDet.cfm?ProdID=132
spoke with Robbie, he is looking for inputs on how to label the new style drivers better on the wesbite cause he is getting lots of questions from guys that cant find them on the website..
let me know in this thread if you have an idea for him, i have to get back to him next week anyways..
What would a change from the stock 8 tooth drivers to a 7 tooth do in regard of gearing.....?
I was plannig on regearing to 19-42 and buy anti ratchet drivers with stock pitch and 8 teeth, but if a 7tooth driver would give me almost the same result then Im money ahed! sled is a 2009 assault......
The 7 tooth, 2.86 pitch driver is .875 the size of the stocker.
The gearing should be about .875 the ratio of the stock for the same track speed at a given jackshaft RPM.
2.86" x 8 teeth = 22.88" circumference....... 7.28" diameter ... 3.64" radius (this is stock on the RMK)
2.86" x 7 teeth = 20.02" circumference....... 6.37" diameter ... 3.19" radius
I got .455" difference between the 7 tooth and 8 tooth clearance.
The 7 tooth has almost a half inch more clearance than the stock driver on the stock track?
