New P22 clutch and Boondocker Talon weights
J
Jstone18
I put a Burandt clutch kit on a ‘24 boost with the updated P22 clutch (the one that can’t fall on the sled if the bolt breaks) and noticed after the install that I can’t adjust the capsules on my Talon weights. See the attached photo. Kind of a bummer since now I’ll have to take the clutch apart to make any adjustments to the capsules. Anyone have this issue and know an easy way to change weights?
Yeah i ran them last year and contacted them about running them with the updated spider. They said they fit other than what you are describing. All you have to do is slight pry/ push the sheaves together and you can take out the threaded slugs. Taking belt off helps so you don't push against it. A decent size flat scew driver or real small pry bar is all you need.
Thank you!
