I think Im going to get rid of my 44-45 mph trackspeed setup and swap it out for the 41-42 mph trackspeed instead. Its obviously much better. Boy I should go back to the books. I guess I had it all wrong.
Joe
Joe
OK.....then what are the gains?
do they make more HP at idle?
Thought I'd chime in here. I'm actually with OT on this one in that this sounds like a legit improvement on the stock TRA arm design. For those who haven't heard of this - and who could blame you, Supertorquer hasn't updated their website in a decade - it's called a Central Roller Arm (or CRA) and it simply is a arm that has the roller in the middle of the arm rather than at the end. This allows the arm to be completely balanced at the point that pushes on the ramp which has some design efficiencies. It is a completely different arm than the Heel Clicker.
I don't have a set yet, but I think hearing from Snowrdr and OT (who I beleive initially didn't think this design would be an improvement) I will be getting one.
Thanks for all your input guys!
Even though your belt hieght is the same I'm woundering if it is just not slipping as much or getting there easier ( faster upshift ) does it seem to pull harder? I cant wait to try the 383 belt.
OT- thanks for the post...been to busy to get to these...they are on my list...BJ
FYI- tuning to peak torque isnt the best idea....the simple reason NOT to is "IF" your rpm wavers or drops off of "peak torque" then theres LESS hp/tq to regain rpm (main problem with the 2007 800r)...clutch to peak HP (higher rpm) then "IF" you lose a little rpm...the motor falls back into MORE torque = kicks your rpm back up...plus at 9000' the 800r runs better at 8100-8200 vs 7900-8000
