Need Help Twisted Turbo wont start
I have a 2009 hcr twisted turbo and it wont start. has no fuel pressure even when pulling it over is the fuel pump gone, how can I test it any other info would be great thanx
Unplug the fuel pump and hit it with a 9 v batttery, you will hear it run and should build fp
Can you hear the fuel pump running when you hook up the battery? If not, ya you need a new fuel pump.
How much fuel ya got in the tank? Filler up at least half way and then hit the pump with the battery. I ran a couple of wires to my truck battery for the full 12 volts. It took a little bit before it grabbed fuel and I thought there was a problem at first too.
Fuel pump
Hook up the wires back wards with the batt. Then hook up the right way. It will work then. My 1000 turbo does it alot.
fuel pump
I would not argue that it has picked up something. But I cleaned tank and replaced the pickups. It will do it after every summer or after it sits awhile. Don't know why. I carry a new pump in my trailer just in case.
I pulled plugs poured some fuel in cylinders it ran for 4 or 5 seconds still didnt get any fuel pressure checked pick ups they are clean. i hooked up the 12v bat cant hear pump pumping, was told to check smart valves are they on the pick ups that work like a diaphram? What do u mean by hooking the battery up backwards you mean to the capacitor ?
get a new fuel pump and be done with it, trust me:face-icon-small-coo
