X
XP Summit
No, your box should not be showing those colors at idle so something is telling it something it should not.
I was only asking about the plugs to make sure it was indeed giving to much fuel as to not enough. The AFR can be funky so was just checking.
Family first!!!
I know what you are saying about those AFR numbers. Weird, but I am sure there is some type of explanation. My gut, as this is my first sled with AFR numbers, is rich... just like a flooded engine need throttle to remain running until it clears out. In this case there is no clear, but remains open. I will pull a plug to verify for you to hopefully take that out of the mix. I would think if it white vs brown then?????
