Where did you get the shock guards? Thanks
the polaris part number is 2876984 (just remember they are sold individually for 2 you need qty 2 of the part number)Where did you get the shock guards? Thanks
Man I can't wait to see my sled when it's all done.
got the new rear axel and 8" billet ice age wheels in this morning... have the front cooler removed and will be putting in the block off plate and uhmw tonight, will post pics of all this as well... any of you guys with RMK chassis not Dragon chassis should do this mod as well... total time is about 15minutes if the skid, track and drive shaft is out of your way... if not probably about an hour job all said and done.. but its an easy cheap way to shave a little weight and get a little more clearance in the front of the tunnel, for now here's a pic of the new wheels installed
Jeremy,
Are you planning to install the UHMV down the length of the tunnel to assist in shedding ice/ preventing build up??
Mountainhorse had posted something about that and said once the drivers and track was out it is a highly recommended mod??
"Simple solution that I cant figure out why Polaris doesnt do... Get a piece of 15.25" wide , 1/16 thick UHMW plastic that is long enough to
wrap inside the tunnel from where the coolers end in the front and wrap to where it exits the tunnel... Rivet that piece of plastic to the inside to the tunnel... There will be NO SNOW or ICE build up in that area PERIOD!!"
The only problem is that you have to pull the skid, track and driveshaft to install it...
Cost for plastic and rivets.... cheap... Thoughts??
Great thread and follow up w/ pics keep up the good work.
akrevrider
