MY intake fix on 2009 summits
W
Wyoming T/A
ACCOUNT CLOSED
simple ifx for the pos design--we should get paid for fixing 1/2 there problems--2 dollars and 2 minutes--3 little clips keep the filter from falling inside the intake
My dealer took mine in on the 10hr checkup and drilled two small holes at each location where you have installed those plastic fasteners...... then he routed a zip tie through them and locked it together... exact same result.. keeps the filter up.
they also installed a flowright on the top of the airbox, but it looks like you have already done that
i think the velcrow would work good too if it will stick i think i seen that on doo talk
I just used a zip tie around the entire filter and wedged the rear corner between the airbox and the nose pan plastic, hasn't moved a bit.
-Seeder
