You can put it right at the bend of the pipe right before it meets the can. Although bending the tabs to keep it in place can cause the base plate to crack over time. Even with drilling relief holes in the corners of the tabs. Well, they crack over time anyways cause they are junk. Ive been making custom steel base plates for years. Using even thinner material than the original base plate, they usually last 10x as long.
