Read the attached instructions from MTNTK. Have the holes welded up and re-drilled for new rivets. Or you could use stainless steel washers on both sides (would look like crap on the outside. The MTNTK cooler mounting rivets use the all of existing holes and add additional mounting for the longer cooler. You would just have extra rivets. Put a wrap on the tunnel, good as new.I only see the 49" version for the 155 or the longer one for the 165. The 155 one still goes way to the rear. Are you talking about the rivets for the stock coolers? I will likely need larger head rivets anyways for the one side as they got pulled through the tunnel. I am interested in these coolers though, that is a much better option than an entire tunnel replacement.
