Murph, I see in the video your also in the 8500 rpm on a brand new engine, what are your plans for clutching if any?
Why do so many guys think turbos need to be geared higher than N/A sleds? I constantly hear this from my turbo customers. They add a turbo and then over-rev so they want to gear up. I bang my head every time because the turbo needs more clutch weight which kills the bottom end as the motor has to try and pull these weights before the boost is built. Just try adding way too much weight to a N/A sled and see what the bottom end is like. Ideal clutching will be light as a N/A at the bottom end but increase with boost/RPM. The weight profile is very important along with helix and springs selection. Sleds that have a poor bottom end or "lag" can benefit from lower gearing as you are simply loading the motor less off the line. When I got my 21 Khaos the first thing I did was pull off the QD2 and sold it, replaced it with a TKI to gear down, and this was a N/A sled. You don't need 80 MPH in the trees.I don’t think qd2 gearing will be too high or an issue.
2.3 is a good turbo sled gear ratio.
I’m not going to be running stock polaris clutching no matter what sled, motor or turbo I’m riding.
Interesting weight. Big slug of weight in the mid-profile area.I also run Tony kit in my n.a. 850 with the gates 47r, and love it. For the boost were going to try some weights from carls cycle, with stock belt and 47r.
