Just wondering how everybody is mounting their sled decks? Turnbuckles? Material ( Aluminum, Galvanized, etc)? Length?
Thanks
Thanks
this is the only safe way to secure a deck to your truck.
So my camper mounts are not safe?
basically the same here.if you have camper tie down I would mount there, I am not sure but I think the ratings on tie down in the box are way lower than what the weight is on two wet sleds and deck....
I broke a hook inside of my truck "2003" not on the deck, but when I broke it I could tell they are not strong if there is just a tiny angle on them.
So I rewelded mounts on the deck and now have it mounted of the camper tie downs with chains and turn buckles. Hasnt moved a hair and SOLID....when mounted inside the bed with turn buckles it used to come loose every now and then which I think caused the stress to eventually break one of my hooks inside the bed.
i use the tork lift frame mounted camper tie downs and use turnbuckles it does not move and i know it is safe.
