This is written like a true pedantic, but I hope it helps. You will have much more fun to ride than trying to sell this sled.
Follow the directions precisely that come with the new kit. If not country cat has them online in thier Manual. (I bought the kit from them)
To get the old shaft out work from the chain case side first. Get it all completely apart. Take off the reverse Gears, main gears and chain, and make sure to put the gears back the way you took them out. take off the snap rings on the jackshaft. Save the thrust washers in case you need them later. The new kit comes with some but every machine is different when re installing.
Make sure to unthread the strange threaded ring around the jackshaft. I did it with a punch and a hammer no problem with heat. Don’t Unthread it all the way, then tap on the ring toward the jackshaft (semi hard) to loosen the tapered sleeve behind the threaded ring. That tapered sleeve keeps the jackshaft from sliding out toward the clutch.
If you don’t free the tapered sleeve you will have a nasty time getting the jackshaft off. I didn’t do it, and heated it super hot and smacked the jackshaft out with a 20 pound sledge in frustration. This tore the chain case seal but luckily didn’t wreck anything else. That was after hours of not knowing why it wouldn’t budge and a few way to many high life’s.
When you tap the threaded ring hard enough you will noticed the tapered sleeve that sits around the jackshaft will break free. Now the jackshaft will slide out. To get out the chain case bearing , melt the green lock tite that sits between the bearing and the chain case. You can use the jackshaft to pound out the old chain case bearing once it’s heated easily.
On the clutch side, Remove the clutch guard and take the chassis mount that holds the fuse box off. Hopefully the bolts are threaded on right. Some of mine were backwards and one took me hours to get off. There was no way to reach it and I had to make a long tool to hold the but on the other end. Remove the gas tank completely. Take a picture of the battery assembly so you know how it goes back together. Don’t break the copper bolts on the battery housing when reinstalling later?.
Remove the knock sensor and unplug it so it doesn’t get messed up when sliding out the old tcl and jackshaft assembly.
Loosen the bolts all the way on the tcl. Mine were on so stubbornly I had to use a breaker bar, a pipe, and lots of heat. I loosened the engine mounts all the way on chain case side too so the engine could tip forward.
I hooked the engine up to a strap and pulled it forward and up to the ceiling rafters to get it to tip enough to “YANK” out the jackshaft and tcl in one piece. You don’t have to be careful with it because it’s getting replaced anyways. Make sure to remove the knock sensor or you won’t be able to slide out the tcl and jackshaft or install the new one.
Make sure when Installing the new jackshaft and tcl you keep the shaft relatively perpendicular to the tcl so the wobble bearing does not come uncased. You will see what I mean. When installing also, it is good to have two people so one can move the engine around as you are seating the jackshaft back in the chain case. (Easy now, it will fit in with a buddy, this shouldn’t take unnecessary force.). Make sure the chain case seal is not damaged. It’s the one in the engine side of the chain case where the jackshaft slips in. If it was damaged, they have some online (m1100t chain case seal). It’s reddish orange in color and will need to be greased after installation.
I bet your motor mounts are both shaky already. Make sure to keep an eye on those after installing the new kit and riding a bit. They are way to soft, but with the torque of the engine being welded to the heat exchanger I won’t dare go with stiffer motor mounts until I fabricate something to get the load off the exchanger.
this project is for pros. I’m not a pro, so it took me a good while and many steps didn’t make any sense for the first few attempts. You can pm me and I’ll face time with you if you run into a wall.
I suggest venting the hood every where and wrap the turbo and exhaust in header wrap. I can not tell you how much this helped cut down on under hood heat. hopefully you have a straight pipe. Makes it so much lighter and cooler under hood. It is also easy to work around and remove.
Yours might be blowing belts because of heat and misalignment combined in most cases I’ve read about. I really want a blow hole in mine, but I have to wait for summer to make some money.
mod rods xxx has an eBay account and they were selling proclimb Vent kits for 60 percent off. They fit nice, don’t be afraid to punch 100 holes in that thing.
good luck, this job might be easy for some, but like I said, it was a multiple day task for me.
Don’t be afraid to send pics over or ask. I would love to help if I can. Mine is still going on that belt, but I am not 100% confident in the job yet. It that same belt survives Monday, this kit will make a full believer out of me.
