I understand that the 20's have a shim in the spider than the 19's didn't under the spider...Might be an issues there with belt tolerances ( sheave offset's)
In 2018 the clutch that didn’t have the shim in front on the spider was used on the low elevation 800 sleds (ZR and XF) And had the taller nut that stops the travel in on the clutch. (Needed because of missing the thickness of shim)I understand that the 20's have a shim in the spider than the 19's didn't under the spider...Might be an issues there with belt tolerances ( sheave offset's)
I had the same issue with my '20 and MDS. Would not pull over 7900rpm. Steve suggested that I needed to get a different spring and try that.. Unfortunately I just took wts out and went back to stock. I had his set up on my '15 and it was night and day from stock in all riding, but then again it was wts and spring as a kit where as the '20 kit was just wts. Hard to beat the stock setup but will try again this winter at some point. Steve is great to deal with!Update: so as you know from this post I purchased the mds clutching about a month ago for my '20. Well, my sled won't pull it for some reason. With the weights loaded to Steve's specs it struggles to get much past 75-7600 rpm. I ended up having to pull all the screws and run just the empty weights to hit between 7800-8000rpm at roughly 8k feet. This is with the 45° helix and also after he sent me a secondary spring to see if that helped, but it didn't. Steve has been helpful trying to figure this out but he seemed at a loss as people are usually not having to run the weights empty until well over 10k ft and he says I should be over revving at my elevation. At his suggestion I had the dealer run a scan on the sled to see if anything showed up, but dealer said everything checked out. Last weekend I put the stock weights back in but left the helix and spring he sent me in the sled. Rpms came back up to 8-8200, but it definitely didn't feel like it pulled as hard down low as it did with the mds. Next ride I'm putting the secondary back to stock just to see what changes. Anyone else not been able to pull mds clutching on the newer sleds or seen anything similar? Anything to look for?
Disclaimer: this is in no way meant to talk down about Steve or his product as I have seen them work first hand, and there are many satisfied customers even with the same sled I have. I'm just looking to share info and possibly get ideas to look into.
VernTime to bring this post back up.
so I finally got a couple rides in with the jaws pipe installed on my ‘20. The few times I got to open her up it appeared I did gain 1-200 rpm with stock clutching other than 45 helix. So since it appeared I needed to bring the rpm down a bit I was going to try the Mds again and see what happened, and maybe try a few different primary springs.
Upon swapping out the weights I did some investigation and found out that the Mds weight tips were resting on the moveable sheaves and then hitting the rollers enough that they were actually holding the sheave probably .025” or better from being able to fully open. I uploaded some photos to try and show the difference.
Could this have anything to do with the performance issues I’ve had with these weights, or is that a normal thing with Mds? I wouldn’t think it’s normal having the weights smashed into the rollers at rest. The stock weights have a bit of room to wiggle when the clutch is fully open. Would it be worth grinding a bit off the tip of the weights to get them to set down in a bit further and allow the clutch to be able to fully open, Or are they just flat not going to work? Those with ‘20s that are successfully running Mds, are yours the same way?
Interesting, so that would mean the spider has to be shimmed differently wouldn’t it? Yours is a ‘20 as well right? Wonder why they would send out clutches with such varianceVern
I just checked mine. When against the roller there is about .125 inches of clearance where yours hit. At rest the weights actually swing a little bit.
I have no doubt that the weights should work, but obviously cat has something going on with certain sled. With my findings of the Mds weights on my sled hitting the rollers to the point it’s holding the clutch partially engaged all the time, I’m wondering if it’s a spider shim variance or something. Especially where CB.8 says his Mds weights don’t hit the rollers at rest and actually have a bit of free play.I tried the MDS in my 2020 Hardcore yesterday and I must say WOW! I was pulling 8200 all day long with them. Those weights combined with the Jaws pipe, V-force reeds, SSI head and a an ECU re-flash REALLY pull hard. They have a ton of weight in them as well for our altitude. I think the stock weights were 70.2 grams and the MDS are 73.9 if I remember correctly. I would have to say the Steve from MDS may be right when he said that if you can't pull RPM with his weights, it's not the weights, it's something else like clutch misalignment, a too low total force primary spring, a too high degree of a helix or some other issue.
I had same experience here in PNW. R’s were the same . Went out again this weeknd , not as deep and heavy . But sled ran like a freight train. You running his helix ? It helped meI rode some wicked heavy weird snow last weekend. At times in could only pull 7950 but still pulled like a freight train. I did pull a washer and installed a new primary spring as it felt like it was starting to get week. Today no matter what I did in any situation pulled Rpms all day long.
The stock spring was a 120/265 per Steve’s recommendation I went with the venom 130/280. No real difference in engagement.
