Update: so as you know from this post I purchased the mds clutching about a month ago for my '20. Well, my sled won't pull it for some reason. With the weights loaded to Steve's specs it struggles to get much past 75-7600 rpm. I ended up having to pull all the screws and run just the empty weights to hit between 7800-8000rpm at roughly 8k feet. This is with the 45° helix and also after he sent me a secondary spring to see if that helped, but it didn't. Steve has been helpful trying to figure this out but he seemed at a loss as people are usually not having to run the weights empty until well over 10k ft and he says I should be over revving at my elevation. At his suggestion I had the dealer run a scan on the sled to see if anything showed up, but dealer said everything checked out. Last weekend I put the stock weights back in but left the helix and spring he sent me in the sled. Rpms came back up to 8-8200, but it definitely didn't feel like it pulled as hard down low as it did with the mds. Next ride I'm putting the secondary back to stock just to see what changes. Anyone else not been able to pull mds clutching on the newer sleds or seen anything similar? Anything to look for?
Disclaimer: this is in no way meant to talk down about Steve or his product as I have seen them work first hand, and there are many satisfied customers even with the same sled I have. I'm just looking to share info and possibly get ideas to look into.
